How to make a Quicktime to RealPlayer conversion easily ?
Some video files require QuickTime player to playback, and every time I try to play such movies an error message appear then I start to go through searching for an encoding software to make a Quicktime to real player conversion as I use Real Player as the universal video player.
Is there a software that is easy to fix this problem permanently?
Best Answer by Huffman Serafin
Answered By 0 points N/A #175667
Hi Kimberly,
There is a program that can convert your videos. You can convert those videos by following these simple steps using Real Player converter tool:
  1. Launch your Real Player which is on your computer, right mouse button click on your video you want to convert and click on "Convert to." The Real Player Converter program will automatically open as soon as the "Convert to" menu item is chosen.
  2. Click on the "Convert to" box to pick the output source or media player you are going to use so that you can access your video you just converted. Click on the "Select a Device" box and click on "Video formats."
  3. Select your video format you want and click on "OK" to save your video in that new format. At the bottom of the program click on "Start"  to start the conversion process.
Answered By 0 points N/A #175669
Hi Kimberly Walker,
In order to use your real player to be the universal video player on your desktop, just do this tip. Every time that you will have to watch a movie, just look at the icon of the media file first and identify if it is a Quicktime or a real player, if it is a QuickTime player default application you can do two ways. First, right click the file and choose open with > real player. The file extension with the chosen file, example my.avi, all the .Avi format of media files will be set to real player by default. Doing these steps with other file extension will monopolize the default program for real player. Another step is by right clicking the file and choosing its properties, change the opens with: option to real player and then set it to real player, same thing goes to the first step. Monopolize the file extensions and there you have it.
Answered By 0 points N/A #175668
Hi dear,
Thanks for asking the question.
I have the good answer in this regard.the real player conversion easily from the many .
there are many websites from where you can download it free of cost.
Here, I am going to post a link to download real player conversion software.
http://www.real.com/resources/video-converter/
Click the link and above and download it.
I hope you will like it.
