How to make reminders visible in QuickBooks pictures inventory.
How to make reminders visible all the time in QuickBooks pictures inventory? Right now it is only visible when it is near the reminder date.
In QuickBooks, you are allowed to add a memo either on customer statements or checks. A memo can help you explain, add relevant information regarding a statement to a customer or check. For example, you can add a description of your company's net terms on a customer's statement. Write a memo in the Memo field of the relevant document's Settings window to make it visible. The memo is visible when you preview the document or print it.
First, open QuickBooks then click the Home icon located in the upper left corner of the window. Next, click Write Checks in the Banking section located at the lower right corner of the window. When the Write Checks window opens, fill out the required information like the check number, date, and or the check amount in their specific fields. For the rest of the instructions, please visit eHow tech | How to Make the Memo Visible on Quickbooks.
Notifications
