hayss tuart
Posted on - 01/22/2013
I have seen on different forums & website about ArcGIS flex viewer reporting software. I often made reports for my office. I don’t know how to use arcgis flex viewer reporting system to generate the report. If you are familiar with arcgis flex viewer reporting then told me how to use it in professional report making.
How to make report using arcgis flex viewer reporting?
This program has been updated with many new enhancements that will make finding engaging and powerful web applications easier than ever. You can use it to create reports of flex viewer on your forum. I can’t really describe to you how to use it, so I will just refer you to the following site for details. https://blogs.esri.com/esri/arcgis/2012/06/25/arcgis-3-0-for-flex-released/
