How to make soft to repair mbr successfully?
Greetings to everyone.
I would like to ask how to make soft to repair mbr successfully?
What do i need to do in order for me to make this repair successful?
I'm open for recommendations and solutions that you could offer.
I would really appreciate it.
Thank you so much for the help.
Answered By 10 points N/A #137774
I have successfully managed to repair my MBR using the following steps in Windows 7:
  • Boot computer to Windows 7 DVD and click on install now.
  • Choose language and continue
  • Select on “Use recovery tools” on the next screen
  • Choose “Command Prompt” as the recovery tool
  • In the command prompt that opens go to the CD drive and access the boot folder
  • Use bootsect command to restore the boot sector  bootsect /nt60 SYS/mbr
  • When completed exit, shutdown and restart to windows
Answered By 590495 points N/A #326645
If your hard drive’s MBR or Master Boot Record is damaged, you can still fix it by rebuilding the Master Boot Record with a repair tool or by running several commands in the command prompt. First, try rebuilding the Master Boot Record with a repair tool. Download EaseUS Partition Master and install it.
Once installed, start EaseUS Partition Master then right-click the drive with the damaged Master Boot Record and select “Rebuild MBR”. On the “Rebuild MBR” window, select the correct operating system or the operating system that’s currently running on the computer. Next, click “Apply”. EaseUS Partition Master will now rebuild the damaged Master Boot Record based on the operating system you selected.
