Toasty Guru
Posted on - 08/25/2016
Hi. I have started using Windows 7 recently. I want to make sticky notes and keep important information on them but I don’t really know how to create them. How to make sticky notes in Windows 7? Please reply ASAP. Thanks in advance.
Ubaid
50 points
How To Make Sticky Notes In Windows 7 Using These Simple Steps
Hi. To learn how to make sticky notes in Windows 7, first click on start, open all programs and then type sticky notes in the search box provided. Click on sticky notes to open it. To start typing, click on the note in the text field provided. The color of the note can be changed as well by selecting it and pressing right-click. Information from the sticky note can be copied and also information from some other source can be pasted on it. The notes can be expanded in size by clicking on the side and can be dragged to by merely clicking on them.
More number of sticky notes can be added by clicking on the “plus” sign indicated on the top right of the note. The note saves whatever is typed in them in an automatic manner. It can be deleted as well by selecting the cross button on the note and when a confirmation dialog box appears whether or not the note is to be deleted, click on yes.
Hope we helped.
