How to make teradata example database.
Hello IT Experts,
I have installed Teradata Express version 13 on my Windows Server. I am newbie in Teradata and don’t know how to use it. But I want to learn it and want to make Teradata example database. Just tell me how to create a simple and basic database in Teradata.
I am looking for quick response.
Answered By 0 points N/A #179574
Hello Emaily,
Teradata database is the best analytical database and designed to deliver high performance and drives complex queries. Teradata expresses 13 contains lots of tools and utilities such as the Teradata Parallel Transporter, Teradata Manager and Teradata Analyst Pack. This has only 10 GB database size unlike Teradata 13.0 which has unlimited size. Using the Service Control in Teradata you can start or stop databases quite easily. I have attached a notepad contain example query for creating a database below with this message.
The following link will direct you to a tutorial about Tearadata which I think will be very helpful to you.
Learn more about Teradata
Thank you.
Rubi Sharlene
