How to make tracks all the same bpm?
30 points
Posted on - 11/25/2012
How to make tracks all the same bpm? Can you recommend the best software that can edit song bpm length? It is very important for me to have them compress with the same beat per minute (bpm) so that I can estimate the song’s length. Your suggestion and recommendation is very important.
Waiting for your support, thank you.
