Hi experts,
My brother is working on a project of the trading system. He is not able to convert complete trading system into excel sheets. Can anyone suggest or educate me in making trading system into a excel sheet.
How to make trading system into an excel sheet.
Hi Boucher,
1.           you did not mention here if your file system is in PDF or otherwise. If your File system is in PDF format you will need to download PDF to Excel converter . Get it from the link below.
https://filehippo.com/
Go to this link and download PDF to Excel converter and install it on your PC .
2.           On the other hand , if your trading system is V card or an Access System you will need to convert it with the help of V card to Excel converter or Access to excel converter. The following link will be help you to download the software.
http://www.fileguru.com/apps/convert_vcard_file_to_excel
Thanks
Amos Marie
 Hi Boucher,
Hope you are doing well. I have read your problem, your brother wants to convert complete trading system into excel sheets. Your need a software named DataConverter.xls. You can download this software form this link.
It’s easy to use. Download this software then setup be it on your PC.
If you have OHLC Data in a workbook, open this file. Enter the column letter for each type of data. Enter  the name of the workbook and worksheet.Then press the convert button.
Hope it will help you.Thank you.
Regards
Kknisely Kate
Hello Boucher,
I suggest to use Adobe Acrobat software.If you don't have it you can download it here http://www.adobe.com and install it.
Run the software and use it to open the trading system which I assume is in PDF format.Select text tool and hold down the Alt key and select the section of the document/PDF that you want to convert.
As it is still selected, right click and choose poem spreadsheet, then export PDF to excel(open PDFÂ that is to be converted, from file menu choose save as and select tables in excel spreadsheet and click ok.
You can alternatively use open to Excel converter to do the same.
