I already have the like button from Facebook, and now I wanted to install the twitter icon to my blog.
The only problem is I'm having a hard time installing this icon.
I get the same number of tweets for every post. I need an expert about this.
Please help me.Â
How to make a twitter button for your blog
As you made Facebook you may try with this. Though I do not know how you did it. Well I have a solution:Â I will tell you about Google Adsense because you would not refer to which blog you want to edit.
* Sign in and see the dashboard.
* You have to select edit for page editing. Then find the Gadgets.
* See their different gadgets what you want to show your main page view.
* Now select the HTML and edit the down one. I mean pasting the Url of your Twitter icon HTML code. You have to keep the paint in twitter icon or image. Then preview the work you have done. Copy the paint link in your blog which is pasted on Twitter account if you want to connect between them.
Thank You.
