I want to make a unique science lab HTML template. I don't know how to build it. What technic I use? What will need to make a science lab HTML template? Please help me to make a Unique Science lab HTML template.
Thanks in advance
How to make a unique science lab HTML template?
To build a custom science lab HTML template, you need to define the requirements of your intended template. You need to ascertain the basic functions you will be needing the template to perform.
Visiting an already existing template could be of help. These could be a great place to look.
When you have an idea of what you require, I would advise 2 options:
1. If you are proficient with Joomla (a content management system), it allows editing and customization of installed templates under the "Template Manager" option in its menu bar. This could allow you to make several changes to the design of the template to suit your requirement.
2. A combination of PHP and HTML would be enough for a basic deployment of the template you require. If you are proficient with both, you could start up something using the requirements you defined earlier.
