How to make video call in Skype for Linux?
Hi guys,
I am using Ubuntu and I use both yahoo messenger and Skype. I can make video call with YM, but it does not work with Skype. What is the problem? How can I make Linux video call with Skype?
Thanks
Answered By 10 points N/A #180622
Hello there,
I need to ask you something first. Did you install skype properly! Did you install all the drivers (video driver) properly! If those are working fine than to make a video call you just have to select a contact from the list and check if he or she is online or not! If that person is online than you just have to click on the video call. If also that don’t work for you than please update your linux OS plus also reinstall a higher version of skype in your computer. I hope the problem would be solved.
Thank you,
 Riley Weaver.
