Hi there,
I have an apple iphone 3gs. The phone is quite sturdy, well built and have tremendous capabilities when it comes to productivity. But recently I have been thinking about make web cam with iphone via a software. I know the best probable way is to jailbrake the phone but is there any solution that doesn't involve jailbraking?
How to make web cam with iphone
Hi Todd,
I don't think there is a good way to set your iPhone as your webcam. Aside from it is illegal, having a third party application might damage your phone and you will face some problem. Better if you buy and use a high quality wireless webcam.
Hope this will help.
Thanks
Hello, I would like to suggest you avoid to use Iphone as web cam. In fact, you can get different software in online. But, you may victim of crashing on software. At the same time, your Iphone may be damaged. So, you can try high qualitative web cam rather use Iphone. It's better for your system also. Best of luck.
Greetings!
There is a way to make your iPhone as a webcam but use it for your own risk.
Here's how to do it.
Requirements:
Wireless Connection
Webcam application for your iPhone and Computer (you can use Webcamera or iWebcamera Turn your iPhone into a real webcamera)
1. Download and install the webcam application on your iPhone.
2. Go to the webcam application developer's site and download the client application for your computer.
3. Install the client application to your computer. This connects your iPhone to your computer.
4. Done!
Note: You can also use your webcam application such as Skype, Windows Live Messenger, Yahoo Messenger and etc. as your client software.
