Mia Molly
20 points
Posted on - 09/27/2012
Hello guys, I just want to know if how to make web shop in asp? And if there are some sample codes offered for free tell me about the website so that I will able to download some as a basis or reference in creating my own web shop. Your suggestions and ideas are very important and will be a big help for me.
How to make web shop in asp?
There are many websites that give free tutorials on how to make web shop using asp. You can also get the sample codes for the web shop. Before you learn these tutorials you need to install the required software on your computer. Make sure you have the latest version of asp and other required software. To create a web shop you need to practice the sample codes and then create a new web shop of your own as per your requirements. You can add elements and features to the web shop as per your requirements. The following are the tools that will get you the sample codes:
1. ASP script poll – You can get it here – http://downloads.fyxm.net/ASP-Script-9359.html
2. ASP script chart – You can get it here – http://downloads.fyxm.net/ASP-Script-110738.html
3. Web Shop 2.0 – You can get it here – http://downloads.fyxm.net/WebShop-35853.html.
