How do I save a web page with Flash and ActiveX to a JPEG image? Is there an option in Internet Explorer for this or do I need a converter software on how to make a webpage JPEG file? I'm using Internet Explorer 7. Thanks.
How to make a webpage jpeg file?
Hey,
As we come to know from your query you simply want to save a webpage in image form. Well, you can follow these steps also press combination Ctrl+ S and save the webpage with whatever name you want to exist in your system.
I Hope this will help you.
Thanks and Regards
Gillam Janetj
Greetings,
For change the web page to JPEG image you have to find and download the HTML to image Converter or save web page as an image or capture webpage as image etc.
There’s a lot of tools, add on and software for this such as Gadwin Web Snapshot, Webpage Capture, Web Page Captor or ThumbPage and many more. So this is up to you which software you want to use.
Have a nice day.
