I would like to make my windows 7 desktop themes unique, obviously the best way would be to create my own theme, and personalize my wallpaper, the window border, the colors.. but is this feasible ?
How to make windows 7 desktop themes unique
Hello Allison Ward,
You can use Windows 7 Theme Creator that is available in the internet for free. This software is compatible for Windows XP 32-bit, Windows Vista 32-bit and 64-bit and Windows 7 32-bit and 64-bit. You can download custom packs in the internet or create your own custom packs and share it to the world. You can modify icons, cursors, etc.
This is also easy to use. Here is the link to its website: http://dewindows7.blogspot.in/2011/05/windows-7-theme-creator.html
Hope this helps.
You can make as unique of a theme as you like, to do so, follow these instructions. Begin by clicking the right button on your mouse, select personalize, now click "background pictur"e to change your desired picture, and select one, now click OK. To change the aero color change and select your desired transparent, then click OK. That's all.
