How to make WMA available on my media player list?
I will just ask how to make WMA available on my media player list. I need this in order to convert unreadable MP3 songs on my iPhone. Please help me. Thank you so much!
Hi Tony,
I have a solution to your problem. You can use total video converter to convert your unreadable mp3 songs. All you need to do is to download the software. I will give you the link.
1. Download the program in your PC. As you can see here.
2. After you download run the program then select the file that you want to convert.
3. After you drag a file in the center you will see like this and you can choose what format you want.
4. Start converting your file until it finish.
