How to make wordpress posts from category? I am using wordpress for my website project but I can’t seem to find an idea on how to categorize my forum posts. Can you share with me some tutorial about wordpress regarding forum posts?
Kristen James.
How to make WordPress posts from category?
Hello!
If you want to create a new category, just click "Categories" under the "Posts" field. Supply the category name, then click "Add Category" in the right-lower portion.
If you want to change the category of a post, click "Edit" (still under the "Posts" field). Find the post you want to edit, and click "Quick Edit" under its title. From the "Categories" section, choose the new category and click "Update Post".
If ever you want to delete a category, keep in mind that deleting the category doesn’t delete the post. It will be set back to default.
Check out this site for other tutorials. Just choose the one you want from the WordPress Services list on the left side.
https://www.siteground.com/tutorials/wordpress/use-categories/
