How to make work of Kaspersky kiss
My Kaspersky have the KISS feature but I don't know to active. Its quite good, my friend said that. How to make work of kaspersky kiss ?
To activate KIS (Kaspersky Internet Security) you need to purchase an activation code from the Kaspersky website. However, you might try using the trial version (only if you have not used the software for 30 days).
To purchase an activation code, go to “Manage License”, then select “Buy License Renewal”.
You was only using trial version that’s why it get expire after 30 days. So to make kaspersky KIS (Kaspersky Internet Security) you have to buy it.
You can visit kaspersky website and download premium antivirus.
Or just simply upgrade your kaspersky and pay for it. All its services will work fine after that.
I thought “KISS” is a feature in Kaspersky but it turns out that KISS actually refers to Kaspersky Internet Security or KIS. Like any antivirus software, Kaspersky is also available as a free download with 30 days trial period. After installing it, your 30 days will start rolling. Now, after your 30 days have been consumed, Kaspersky will stop working and will prompt you to purchase it.
This is when you need to purchase a license for your Kaspersky Internet Security so you can continue using it for your computer. You can also activate Kaspersky while it is in trial stage by purchasing a license. A license is required to activate the product. To purchase a new license, visit Kaspersky Internet Security 2015.
To download the latest trial version, visit Kaspersky Internet Security 2015 Trial. It still includes the 30-day trial period. As a reminder, there is no way you can activate your antivirus product or security application without purchasing a license code and there is also no way you can acquire a license code for free.
