can anyone tell me how to make your LAN work faster  for USB modems and for USB routers?
How to make your lan work faster
To make your LAN working faster you can upgrade your modems and router.
You can also decrease the number of computers used in the network. You may speed up some by lowering your cookies and by decreasing the number of history temp files. Use better cable for USB routers.
You also can use some software's that helps to make your LAN working a little bit faster.
If you want to make your LAN faster than before you need to upgrade your modems and routers. Decreasing the number of computer in the network we will also be able to make your LAN faster. You can also add more bandwidth in your network.Â
