How to make yourself fat web cam?
Hello fellows,
How to make yourself fat web cam? I would like to know what my appearance would be if I am fat. Guide me along the setting to configure this kind of application. I am using windows 7 64 bit operating system. This is just for fun, I hope you will help me.
Kimberly Walker.
Best Answer by White-coffey
Answered By 0 points N/A #175587
Its look like you want to enjoy with yourself. There are many webcam application allow you change your face, image, background and your shape as well. Each software have different effects.
ManyCam: Its free software. You can apply different type of graphics on you output image coming from your webcam. You can use this with Skype, yahoo messenger and MSN.
SplitCam: animate yourself, change your background. You can also upload your video on YouTube using this application
WebcamMax: this is the best application having thousands of effects but it’s not free only 30 days trial .if you want to buy if fee will be 30$.
Answered By 0 points N/A #175588
There is some free software that make yourself fat to look. "UniArgus Express Lite" is one of them. You can get it from the following link- http://uniargus-express-lite.software.informer.com/
You can get android supported app that will make you fat to look from here- https://www.appszoom.com/android_applications/entertainment/make-me-fat-fat-booth_clqzn.html
There is also many free software in this site. You can get them free from there.
Wish you good appearance in fat.
