How to manage a blog?
Asked By 130 points N/A Posted on -
Recently, I have started posting some articles in my new blog. Actually, I'm new to blogging. How can I make my blog to show up on Google? How can I apply ads in my blog? I'm on blogger. What other things can I do in order to make my blog popular?
Answered By 10 points N/A #193619
In order to make your blog available on search engines, you have to submit it to them.
When you let them know about your blog, your blog will be indexed faster and appear in search engines.
To make your blog appear on the first page of the search increase the number of your blog views by creating your profiles on various social media and promote it.
Include relevant videos and some good attractive images in your blog.
Showing Ads
1. If you want to display ads in blog, go to Layouts tab.
2. In the Blog Post, Click edit.
3. A dialog box will appear to configure your blog post.
4. Check the box that says Show ads between posts. ( Before checking this box you have to sign up with AdSense)
5. After checking the box, you will get a configuration option. Adjust the options as desirable.
