How to manage digital images using Enterprise computer image management?
I'm new to Enterprise and I'm trying to manage and track electronic documents which includes digital images. I'm going to apply it to a B2E system. Does someone know how to use Enterprise computer image management? Please help.
Best Answer by Devorett Carlson
Answered By 0 points N/A #153642
Dear Ferrari,
I've read your question carefully but I need to know more about your question. There are too many enterprise software launched by different companies. Let me know which enterprise you are using to capture your electronic documents?
Then it will easy to give you exact solution.
Thanks
Answered By 0 points N/A #153643
Hello Ferrari Donaid!
Enterprise Content Management (ECM) will let you store various documents of an organization.
Enterprise Content Management is used for document management, collaboration, web content management, work management, records management and business process management.
For more information and work processes related to ECM, Go to this link.
Hope you will get a lot of information from it.
Have a good day.
Answered By 10 points N/A #153644
Hello Ferrari Donald,
It is a quite easy job. It includes,
Capture an image from a source system
Deploy an image to one or more target systems
Restore a snapshot image to recover a target system
Also refer to the following links:
http://www.dhitllc.com/DigitalXRay/EnterpriseImageManagement.aspx
http://searchcio.techtarget.com/definition/B2E
http://www.ibm.com/smarter-computing/us/en/technical-breakthroughs/image-management.html
Please educate yourself with these sites and you will be comfortable with your job.
Thanks
