Hello fellows,
How to manage games on ps3? I just got my ps3 and wondering on how to manage all the setting properly. Well I am not really used to it, my question is how will I be going to setup or manage all the features that the ps3 have? I need your suggestions.
Thank you.
Hi Isabella,
Steps are as follow;
1.Have your PS3 connected to the Internet according to your preference/PS3 model. It’ll be either, via Ethernet or wireless. Now, let say if you prefer to use Ethernet, connect the cable to your PS3, Hi,
But if you’ll be using wireless then no need to attach the cable, go to “Settings” > “Network Settings” > “Internet Connection Settings” select “Yes” when prompted to disconnect to the internet. Now select “Easy” then select “Wireless”, select “Scan” for you to be able to view the access point that you’ll be using then enter “Encryption Key”. And save your settings.
2. Select “Sign-up for PlayStation Network” enter all the necessary details.
3. Select “PlayStation Network” enter your user name and password to sign in and “start the game. Please visit this link: http://www.ign.com/wikis/playstation-3/PlayStation_Move for your reference on how to set up PS3 and manage its features.
