How to manage if the security token was missing?
Can you help me on how to manage the issue if the security token was missing errors and how to prevent future occurrence?
Are you receiving this error on your browser such as Mozilla or Chrome? Please try to clear your cache and cookies. If you are using Mozilla, select the Tools and then click Clear Recent History. Tick the cookies and cache check boxes and then click the Clear now button below. If you are using Chrome, click the 3 bar button (the wrench button on the previous version) and then click the History.
A new tab will open. Under the History tab, click the Clear Browser Data and then tick the Cookies and Cache check boxes and then click the clear button below.
