jim bbauman
10 points
Posted on - 04/23/2013
I need to manage remote desktop for mobile . I want it from any where from pc without any connection between pc and mobile . It will have to work for shut down or restart processing . But I don't know the way, how will it be possible ? Please help me anyone.
How to manage remote desktop for mobile?
Hi Jim, certainly it is possible. There are a lot of apps available for pc remote control using mobile phones. There are apps like LogMeIn Ignition, Jump desktop, Splashtop Remote Desktop, VNC, Wyse PocketCloud.
Also, I will recommend you this site http://www.rdmplus.com/ which is about Remote Desktop for Mobiles that supports all Mobile platforms.
You can try these options I gave you and see which one works for you.
Hi JIM,
Well first of all you should understand that there are two different categories of a remote desktop.
1. To access your PC from home using your cell phones blue tooth connection.
2. To access your PC using an IP address: in this way you can control your PC from all across the globe.
For the former please visit this Bluetooth Remote.
For the Later visit this.
Hi dear
Thank you for your question.
Use the following way to solve your problem.
♦ First download rar file from the following site Ziddu
♦ Open the rar file . Here you will find two files.
♦ Open the exe file and install the file below.
♦ Install the Remote Professional icon on the desktop, click, Open View software.
♦ In your mobile Bluetooth / USB connect with me, please remember Pc Suite USB mode on.
♦ The Mobile Application > Installations > RS60pro open, option > connect via Bluetooth / connect via USB and select.
Hope you find the solution
