How to manage Saved IE Password?
Asked By 7060 points N/A Posted on -
Can anyone please help
Thanks in advance
Best Answer by James20
Answered By 5 points N/A #79463
Hi dear
Post here question's  you post answer here this is not question.
When you enter a user name and password, Internet Explorer may ask if you want it to remember the password.
Click on Yes and it will automatically fill in the password next time you enter that user name.
But if you check Don't offer to remember any more passwords, then whether you click on Yes or No, you won't be prompted again. To recover this feature, launch Internet Options from IE's Tools menu,
select the Content tab,
click on the AutoComplete button, and check Prompt me to save passwords.
To delete an individual saved password entry,
go to the log-on box on a Web page and double-click.
Your saved AutoComplete entries will drop down.
Use the arrow keys to scroll to the one you want to delete, and press the Del key.
Answered By 0 points N/A #79464
Open the internet explorer – tools – internet option – content tab – under autocomplete, click on settings – check the box for user names and passwords for forms. Click on ok and then apply for the effects to take place. Close the internet explorer start it again.
