I am using Windows 7 on my Desktop PC. I Keep My PC Always ON. Please tell me how can i change win 7 power plan to set power consumption Minimum. Is there any option to set a power plan according to System Timing.
Thanks in Advance.
How to manage win 7 power plan?
Hi
Mcray In windows 7 you want to change win 7 power plan to set power consumption so you should to go setting option and can set minimum available consumption and set it in as you told your PC always ON so you should to do this process.
Hopefully this information will help you.
Thanks,
Raun Nelson
I would suggest you set to sleep mode. Do this by going to control panel-Go to-power Option- Click change setting -Select the time that you wish to. You will be able to reduce your power consumption and hopefully save your electricity bill.
Thanks
Amos Marie
