How to manipulate Skype humoticons
Desiraealexa,
Creating your Humoticon for skype instead of emoticons is relatively easy.
All you require is either a photo album on Facebook, on your system, and a webcam to take new pictures.
Also and most important for the time being is a Facebook account. Simply go to the following link: https://apps.facebook.com/humoticons/ login with your Facebook account, and get connected with the Facebook prompt (as usual) to connect with this application.
The result will be as per figure below which is very easy to follow.
Either click on “select a photo from your album”. And you will be given a choice to select any photo from your album on the Facebook, OR use your profile picture
OR click on “take a Picture From your webcam” and follow the steps 1,2,3. You will be asked to either copy the url to use anywhere, or download the gif to upload and use.
PT
you can create your own customized humoticons by capturing your pictures of your facial expressions by snapping an image with your webcam .
go throw this IRL : https://apps.facebook.com/humoticons/ and start creating your own humoticons , it's so easy.
