How many add columns in table?
First open correct document. select the correct columns. click table menu, click insert, click table. up to show the table dialog box. press any Character in number of columns. click ok.
First open document. then follow the steps-
1)click insert.
2)click table.
you can see options table and column.and the number you want.
then select the number of column and row.
press ok. thats it.
For add columns in table just 63 columns.
Steps to find out:
1. Click insert menu
2. Click table
3. Click insert table
4. Input number of columns more than 63, example : 64, 65, 66, etc.
5. Click ok
6. Then,,, you can see a message : "The number must be between 1 and 63"
