How many days once does Google drop the index
Say i had a blog in my website which is indexed by Google and now i have deleted it. Now after 15 days also when i search Google shows that Blog which i deleted and when clicked goes to page not found.
Is there any help with this?
Best Answer by Shane Gomez
Answered By 0 points N/A #122281
Hi Jaipath,
There is no fixed number of days or months after which Google drops or re-indexes any pages. This depends on many factors such as your Google Page Ranking, links to your page, and crawling constraints such as the number of parameters in your URL. There could be numerous reasons that affect the crawl frequency. Sometimes your home page can get re-indexed earlier and other pages later.
They actually follow the algorithmic crawl process which means, Google's computer programs decide which sites to crawl, the frequency, and the number of pages to index from each site. They don't even accept payments to increase frequency of index to your site.
You may read Webmaster Guidelines for additional information on this link:
Good luck.
Answered By 0 points N/A #122282
Thanks a lot guys you people Rock techyv
Love to be here
Answered By 0 points N/A #122279
Hi dear
Google won’t remove your URL until you request. Google may remove your web site but not the URL. This is happens because of the rankings and the indexes of the Google .Because Google doesn’t control the site in the search result and those are controlled by the webmasters of the sites’. So if you want to remove the URL you have to use URL removal request tool. Use following link and follow the instructions to remove your URL.
Google don’t have an exact time period to remove a site from the web. They use an mathematical method to indexing for the web sites.
