How many file types are available in Red Hat Linux?
Hi Noel,
In Red Hat Linux you can find seven types of files those are given below. When you type
# ls -l /dev | less command you can see the following file types in there.
– regular file
d directory
l symbolink
b block special file
c character special file
p named pipe
s socket
I have left two examples here, c and b has different meaning in file type
c type file are use to communicate with hardware
one character at a time .
b type file are used to communicate with
hardware a block of data at a time.
512 bytes, 1024 bytes, etc.
Hello Sammy,
Linux supports many different file systems. To see the Linux file system hierarchy as follows, use tree-L1/ command.
If you want to know more about Linux operating system or have any other query then don’t hesitate to ask.
Thank You.
Since it’s all about Linux, the Red Hat Linux, which was the main concern of this page, was a widely used Linux-based operating system that was created by the Red Hat company.
It was later discontinued on 2004. The Red Hat Linux 1.0 was the first Linux distribution released on November 3, 1994 that uses the RPM Package Manager as the packaging format. This served as the standard packaging format used on other distributions like Yellow Dog Linux, and Mandriva Linux.
They started the discontinuation of the Red Hat Linux line by 2003 to give way to RHEL or the Red Hat Enterprise Linux. The Red Hat company also supported the development of Fedora which is the free version and is best for home use.
The very last version and final release was Red Hat Linux 9 and its line was finally ended on April 30, 2004. The updates for the last version were still available until 2006 and it was finally shut down by 2007.
iPod Linux booting Linux
