How many hardwares a pc must have?
Hardware are those physical parts which you can see and touch as well from your hands and software is the category which is not visible and you cannot touch it and feel it. There are many parts of hardware of a personal computer. The main part of the computer is CPU which is the central processing unit of the whole computer. It is made of different parts itself such as it consists of a motherboard with processor, Ram, Hard disk and power supply. The image of the motherboard of the computer system is shown in the following picture which will clear your concepts about this part of hardware.
There are lots of physical peripherals that can be counted as hardware. All tangible materials that you see as part of a computer are called hardware. The following lists are samples: Monitor, Speaker, Headset, USB Flash driver, Modem, Pointing devices, Keyboard. camera, printer, UPS and a lot more.
If you want to know all the lists with its function you may refer to this site:
Hope it helps.
Dlanear
