Hi guys, I came to know that some camcorders are also offering two and three SD card slots so that it wil be easier and preferred by user to save media more and more. And while searching for this special feature I got know about JVC Everio camcorder but its not mentioned in the list that how many slots it has .Please tell me the answer.
How many SD card slot does JVC Everio GC have?
John,
Checking up on the features list, it says that this camcorder JVC EVERIO GC PX -100 just have one slot where you can connect either three types of memory: SD, SDHC, SDXC.
The advantage on the SDXC is that this is not a FAT 32 partition but an ExFAT partition, what lets the memory to be up to 2 Tera bites storage capacity and run at highest data transfer speed, This is related to what you are looking for more storage possibilities.
Below is the link to check the specs list if you need it
EVERIO SPECS
Hope this helps
Riley
