How to map m2ts extract audio to another file in software?
Hi to all,
I have some m2ts files and I want to extract audio from m2ts files and then map to other video file. As many softwares are available on the internet but they fail to maintain the quality of audio. I have also tried to convert m2ts file to another format but it did not work. Please let me know how to map m2ts extract audio to video in such a way that video quality and audio quality none of them are affected.
Some suggestion please.
Answered By 30 points N/A #167987
HI,
If you discover about the option with this problems, then it seems merely the actual antiquated message boards are you trouble-shooters. In addition to these kinds of specialists will certainly show you open your own first M2TS jar (more complicatedly many people claimed demux), then uncover your own bothersome DTS audio tracks record, make use of a few just about User-friend system to transcode DTS audio tracks to AC3 codec, then remux results in a fresh M2TS jar record. Fine, it seems carried out. Although afterward, you still have to look at whether the end result audio tracks syncs along with video. Otherwise, all you've got carried out screwed in place!
Although soon after looking over this M2TS DTS audio tracks to AC3 Change course, often away one-click way to resolve this problems.
Otherwise you can download WinX HD Video Converter Deluxe. It will give you ultimate control power over your video.
Thanks
