How to mass print documents Mac ?
I want to mass print documents in Mac without opening them because it takes too long to do each one separately. Is there any way to do so, if it is then please suggest me how to mass print documents Mac?
Hello Kurtra Bon,
Good day!
It's good to hear about your inquiry. Yes, it would be much easier if you could do mass printing of documents. Here are tips to help mass print documents.
First, you need to convert the documents to PDF. Then once they are already in PDF format you can easily use the 'finder' part of Automator there looks to be a 'print finder items' basically drop your files in there after which you can select your printer.
You can also try this. Go to Printer Setup Utility>Go to Show Printer List>select the printer you want to use>choose the files that you want to print and put in the Window. You can now start to print.
You may also find this option how to print using Preview. First>Select all the PDF file that you want to print> drag and drop onto Preview (all files will be opened) >then click and highlight a file> then Select All, you can use "Command key plus A" (files will be highlighted>then go to Previews File menu and chose to Print documents. You can now print the documents.
Good luck!
Rios Louise
