Hello fellows,
How to merge dat files in mac? I have 12 .dat files in my computer with mac operating system and was confused on the proper software needed to merge those 12 files as one. One more thing, can I zip a file using mac operating system? I need some help from you experts.
Chloe Chylly.
How to merge dat files in Mac?
Hi Chloe,
You can use Mac DAT editor to merge your .dat files. Mac DAT editor is an easy-to-use program to Mac for editing .dat files including merging of files in Mac Operating System. Here is the link including the tutorial on how to edit/merge .dat file:
http://www.videoeditorformac.com/dat-editor-for-mac.htm
About the zip question, yes it is very possible. There are many software/program to use in order to zip or unzip a file and it is available for different Operating System. I recommend to use and download the installer here:
https://www.techspot.com/downloads/5169-winrar-for-mac.html
Hope it'll help.
