Hello fellows,
How to merge or join divx mac?
Is there a way that we can join or merge two or more movies in a divx movie player?
My mac operating system is not that easy to operate or manipulate so I be needing so much of your help for this.
Give me some instruction to be followed to get this done properly.
Kristen James.
hasnat21
How to merge or join divx Mac?
Hi Kristen,
How are you? I see you are having problems wit joining Divx files in your mac. Here are some solutions you can try to solve your problem.
1. Try and use ffmpegx software. You need to join two Divx files at a time.  Just select the two files and join them. Afterwards you will get a file with .avi extension. Then if you have more files to join just browse for the .avi file and join your third Divx file with it and so on. It's a bit tedius though.
2. use QuickTime pro is a great software for that purpose. Just use copy+paste for your divx files and it joins them at the click of a button.
3. You can go to https://software-download.name/join-divx-files-mac/ and free download the software from the top right corner after that, just follow these steps:
Click on add files to load the divx files
Click the off button next to add files, it will turn the joiner on. If it's on proceed with next step.
Click the profile button and select your output video or audio format.
Now click the check box for merge video files together option for mac.
Click the bended arrow to execute the operation.
Click the button on the middle to open your files and you are done.
Happy Joining files KristenÂ
Hi Ms. Kristen James,
Here some ways on how to join DivX files into one on Mac os
To load your DivX video files, you can see ADD FILE on the top menu and CLICK IT.
Turn ON video by CLICKING OFF button next to the ADD FILE. ( If the video is already ON, proceed to the next step)
To Select output video or audio format, CLICK PROFILE drop-down list at the bottom window.
For joining mac DivX movie, you should CHECK the option MERGE VIDEO FILES TOGETHER.
Click the BENDED ARROW button
Check the joined files by clicking OPEN at the bottom middle.
Good Day!
