alfonso ty
Posted on - 03/08/2012
I merge Excel with Word to print billings for a little business. Now I have branches I want to have it online so that my employees can use it, also to monitor their billings. Is there any way to do it without buying software?
How to merge Word and Excel online?
Dear,
I have understood your problem and I have a solution for you. This will resolve the problem completely.
I have added a link which will surely helps you to diagnose the problem. The link has a complete detail of merging the word and excels online. And how can you do this perfectly.
https://www.internet4classrooms.com/msword_formletter.htm
This will helps to understand how this merge has to be done correctly and how it can be operated. As well as different features are also given. I am sure it will increase your knowledge.
Hope you got the answer.
Best of luck for your future.
Hello Alfonso ty,
You can have your merged Excel simply in online with Google Docs.
But, sometimes Google Docs seem not too private.
To fix this, you may like the following software:
1. Teamlab Office CLOUD BUSINESS COLUTION, which you can find from here
2. Zoho Simple Online Document Management, which you can find from here
Hope you will select a better one from these two.
Have a nice day.
Paul Jolie.
