How to migrate linux url dns filtering with url rewriting
Hi expert,  I am migrating  the solar server to Linux .  Is it is  possible to transfer the solar server to Linux by using the same URL.  I  am not really aware of migrating solar server to Linux url dns filtering.  I assume it is possible with URL rewriting . Any material would be a great help that explains Linux url dns filtering which can be used to migrate from solar server to Linux with filtering of URLs.
Best Answer by Wade S Veith
Answered By 30 points N/A #131291
It is not that easy, rather make it a habit to start screen as the primary thing, and for the actual problem you have to launch your job from the terminal, you have to background it by typing ctrl _ Z and after that bg and detach the job from parent shell and in bash disown -h %<jobid>. and after that you will close the terminal and see the job running.
Answered By 65 points N/A #131292
Linux is a Unix-like computer operating system assembled under the model of free and open source software development and distribution. The development of Linux is one of the most prominent examples of free and open source software collaboration: the underlying source code may be used, modified, and distributed commercially or non-commercially by anyone under licenses such as the GNU General Public License. With regards to your query, make sure both servers are on the same network. Run Solar Winds Trivial File Transfer Protocol (TFTP) and configure. Start TFTP server by clicking start button and to make sure service has started, you have to check status.
