Hi to everyone,
How to minimize hon mountain lion? I am using mountain lion operating system and while playing HON or heroes of newerth game it was always on the default full screen mode. I just wonder if how to minimize the game while I am doing some other stuff? I need some help.
Your suggestion is very much welcome.
Good Evening,
Hi, if you are having trouble on how to minimize or hide other applications like when you are playing HON and you want to do other stuffs, use can use “command tab” so you can go to different applications.
Or you can also just click the “esc button” and this one also, “command `/~”
https://support.apple.com/en-us/HT201236 you can also go to this apple support link to learn different keyboard shortcut keys.
Hope it helps.
Hi Markusa
Try the options below and hopefully this will solve your problem.
Option 1: While on the games screen, press the "COMMAND+F" or "COMMAND+M" to minimize it.
Option 2: Go to System Preferences→Appearance. Check the "Double click a window to minimize" option. Now you just need to double click on the upper part of any active window to minimize it.
