Hello friends,
This is all about scheduled task minimize window. I cannot find the minimize window for scheduled task manager, is there a way that I can minimize the window? When I am using any program application such as Skype and internet browsers, I would also like to check my task manager processes.
Thanks and Regards,
Deborah Hall.
How to minimize the Scheduled Task window?
Hi Deborah,
               First of all make sure your taskbar is not locked? If its locked then unlock it, and when you use applications like skype, internet browsers etc, minimize it and it appears in your taskbar at the bottom of your screen so that you can maximize it again whenever you want. If you want to switch applications then just press WINDOWS+TAB simultaneously and you'll be able to switch applications one by one.
If you want to check how many applications are running and if you want to close any of them, then just press CTRL+ALT+DEL and select Start Task Manager and here you can manage all your applications.
Enjoy!
