Hello experts,
How to modify the setting for fast cursor? When I am playing computer games I need a fast cursor so that I will be able to wave some skills from the opponent and I don’t know how to configure or adjust a setting for this. Computer experts, help me regarding this issue about mouse sensitivity.
Thank you.
You can change the speed of your mouse wheel by doing the following:
1. Click Start> Control Panel> Hardware> Mouse.
2. Under the Wheel tab:
You can change the number of lines the screen will move on each mouse notch movement. Just click on "The following number of lines at a time" and enter the number of lines that you want.
Click "One screen at a time" to scroll on the entire screen.
    OR
You can also go to Start> Control Panel> Mouse. The Mouse Properties window will appear. Under Motion, select the pointer speed. Adjust the slider to slow or fast. Click OK to save the settings.
It's easy to customize mouse pointer speed. To change speed Open Control Panel and search for mouse properties. Click on Mouse Properties, a new window will appear containing mouse settings. Click on "Pointer Options" tab at the top.
First option will show a slide. Drag the slide towards right to increase mouse pointer speed.
