How to monitor Internet connection to troubleshoot Internet connections
Hi. I am not very versatile with the computer related tasks. I am having problems with my Internet connection in Windows 8 from a few days. How to monitor Internet connection? Please reply ASAP. Thanks in advance.
Answered By 0 points N/A #93135
Hi. To learn how to monitor Internet connection to troubleshoot the problem with Internet connections in Windows 8, first move your cursor to the right following which type settings in the search bar. Then, select the icon of the wireless network. If more than one network appears on the screen, then select the one which you would like to join. After the network is selected, you need to enter the password for the same and you will be connected to the Internet.
For Windows 7, first select the network icon from the desktop which appears after the arrow next to the system tray is selected. Next, from the list of networks available, select the network to which you would like to connect following which select the connect option after entering the password as required.
Hope we helped.
