How To Mount Image Windows 8?
I am a Windows 8 user. I have an ISO file to install a software. I am not able to open nor extract the files. Is there any way to open the file in windows 8?
You totally need not worry if you have windows 8 as it has a default ISO mounter and reader. Which is supposed to automatically open when we double click but if for some reason it is not opening follow the below given steps.
Step 1: Right click on the ISO file and from the popup windows that appears select “Properties”
Step 2: Click on change button and Select windows explorer from the small box that appears.
Step 3: Click on the OK button and now you should be able to open the file from there itself without requiring any app.
