Rian Park
Posted on - 08/25/2016
Hi. I have recently started using Apple phone. I am not very sure about the way it operates. I need to move some applications to another screen but don’t really know how. How to move apps on iPhone? Please reply ASAP. Thanks in advance.
How To Move Apps On iphone In Easy Steps
Hi. To learn how to move apps on iPhone, first click on the app and hold it until it’s icon begins to shake. After the icons begin to shake, they can be rearranged in the way you want to. The icons just need to be dragged and dropped to a new place on the screen. If at all the app is to be moved to a new location, the icon needs to be dragged to the left or the right screen until a new page appears. After you have reached the location where the app was to be moved, release the icon of the app and drop it to the new location. Click on the home option to save the changes which have been made. You can also create a new page by clicking on the app or folder until everything on the screen begins to shake.
Next, select the app and move it to the new page by dragging its icon. To drop the app on the next page, release the icon of the app. To save the change made, select the button named home.
Hope we helped.
