royalLC
Posted on - 11/30/2012
When ever I use MSN at a cyber cafe and later I log in to my MSN from my home PC, I find my chat log has been automatically cleared. Is there an option to enable msn log, save on server? Please give the path I should follow to enable that option.
Thank you.
How MSN chat log, save on server can be enabled?
Up to my knowledge and expertise there is no such thing which can save your MSN Messenger chats on server side. The only thing is that you can save your chats on your computer hard drive or a flash drive. However, if you are using Gmail Id either on talk or chatting from Gmail website then your chats are saved in your Gmail account and are present in a folder named as "Chats".
The answer is no. MSN does not allow logs to be saved in server as its archives are local as in you can change your pc settings to save the logs (basically in your “my documents” folder) and use them later but as far as saving on server is concerned count msn messenger out. If you are using public network or pc momentarily try modifying the save options from tools menu and save the logs manually.
Sandara Alex
