Hi, experts! One of my friend was dealing with my project with MSN temple file development. Actually, we were working for managing a new project. But, she is out of the country. Now, I need a tiny help about msn messenger temp file get chats. Can anyone help me?
How MSN messenger temp file get chats
Hi Robert,
Good day!! You can install a messenger plus live extension called File Transfer Plus, it gives you a plethora of options, and you can resume any failed file transfer until it’s complete. There are also several file recovery programs that could retrieve the incomplete download, focus on the indicated Temp folder since that’s the only place where they are kept.
Thanks
Hello Robert,
It looks like you need some help with MSN messenger temp files. You need to add an extension to your MSN messenger which will allow you to transfer any file which was not transferred properly on previous occasion. You will also find a few file recovery programs like File Transfer Plus, if you want to retrieve an interrupted file download. But for the chat history, you need to look in the temp folders.
I hope this solves your problem.
