Hello and good day!
Since 2009, AutomatedQA’s TestComplete was given an honourable award by the readers. And as the time passes, the product becomes more improving. Adding some features, and other capabilities. Now is a member of Smart Bear Software. Since its improved version was released. I want to use this AutomatedQA TestComplete Enterprise 8. How much does it cost? How to install it.
Any help would be nice. Thank you very much
How much is AutomatedQA TestComplete Enterprise 8?
Hello Hunter Chasee,
If you want to use the automated QA test system then you can get it from the below link that is a good software of testing. But it is in trial period you can use it and if you like it then you can put that full software as per your need and you can also demand for the changes in your software to the authority by paying some of the dues to them. In the link there is a complete description of the software and you can get it by paying a very low amount.
https://smartbear.com/product/testcomplete/overview/
