Ava larry
10 points
Posted on - 12/01/2012
Hi
How much is the cost for android prism?
I just heard about mobile prism with android operating system and was interested in having one. I need to consult you first on the possible features of this mobile phone before buying one.
I have to be sure enough that I am investing for the right stuff.
Ava Larry.
The T-mobile android Smartphone prism comes for a 2 year contract at $20. It is an entry level Android phone, that comes with a 3.5-inch screen and 3.2 MP camera. It has a 1400 mAh battery. If you are new to the android OS, this might be a good phone to start with. One drawback of the phone is that it supports 3G only.
bathie
If you are buying the handset only, you're going to be looking for $150-160
bathie
If you buy the handset only, you're looking for $150-160
