I have seen a lot of development in Google when it comes to their applications. I extensively use their Google Documents and their Google Plus. I wonder how they are earning from these apps? Is there a monthly cost for this? If yes, what are the benefits of paying Google to use their apps and how much is the Google apps monthly cost?
How much Google apps monthly cost?
Google Apps does not have any cost. They giving away the Documents and Google Plus Apps for free but if you will avail Google Apps for Business you have to pay $5/user/month. They are earning from Google Apps that is for business. Google Apps for Business gives you your own domain, 24/7 Technical Support, Disable Gmail Ads, It also lets you use their Google Drive for uploading and sharing of your documents.
Hello Donal Bambie,
Google application is one of the developments of Google. We are using Google Documents and Google Plus. There is monthly cost for this Google application. Google Application pricing is given in a table which you will get in the below link.
https://en.softonic.com/downloads/motion-games/free
Just click the below link and get your information.
https://cloud.google.com/pricing/Â
